How do you remove a heat exchanger?
JakeT721
I have a 1985 Mercruiser 170. It was having some problems wanting to overheat, so I replaced the impellar but the problem persisted. I did some poking around and realized that the no seawater (hose water) is getting through the heat exchanger to the exhaust manifold. I decide to pull the heat exchanger so that I can pull it apart and clean it out (with engine still in the boat), but now that I finally have the two brackets off - I cannot for the life of me get the exchanger to budge. It almost feels like it's welded to the block. How does one remove the heat exchanger?
---Jake---
alldodge
Re: How do you remove a heat exchanger?
:welcome: to iboats Jake
There are usually only 2 brackets holding a heat exchanger and you have removed those. Next I would request pics so we can see what your seeing
Capt. Click
Hey, yes there is only 2 hangers that hold the heat exchanger in place. The first time I removed mine it was stuck to the mounts. You may have to give it a good bump towards the end to break it loose, kinda see saw it back and forth on the mounts. Be careful the exchanger is pretty heavy, the weight of it will surprise you so watch your fingers when it breaks loose.
"GET 'EM OFF THE BOTTOM "
Bt Doctur
I have never seen one get that clogged before. Are you positive it wont pass water? Being a free flow system , water cant go in unless it CAN GET OUT.
Only exit is thru the riser. Or the water coming from the pump is not making it to the heat exchanger.Pull the drive and just use a hose in the water inlet.
Water should free flow thru the system and out the exaust.
Bt Doctur
stonyloam
I'm with the doctor (kind of LOL).Pull the inlet hose off the front of the exchanger, and pull the outlet hose (that goes to the exhaust elbow) off. Stick a garden hose in the front inlet and see if water comes out of the outlet. If it does not, pull the endcaps. Front one first and check the starboard side holes, as that is most likely where the clog would be (impeller pieces etc). If water flows freely, stick the hose into the hose going to the exhaust elbow, it should flow freely, if not, that is where your problem is, the outlet in the elbow would be clogged. Don't make any more work for yourself then necessary.
JakeT721
Thank you guys all very much for your input. Sorry I've been MIA after asking this question...I'm working on my ph.d and teaching some undergrad classes and got slammed with end of the semester crap. But now I'm able to start working on this boat again. I'm going to try the trouble shooting bt doctur and stoneyloam suggested before I yank it all the way out. I just have to tiptoe through all of this as I really don't know what Im doing. Thanks again guys!
Your not going to be able to take it apart anyways. Only the end caps. It has several tubes that run horizontally and they are all soldered in there. nothing to take apart.
Was the impeller missing any pieces?
if your is toast, I have a good source to have it repaired or replaced.
JakeT721
The impeller was devastated. My hope in removing the heat exchanger was to just get it out and do my best to clean out anything that may be clogging it up.
How does one know if the heat exchanger is "toast"?
if you pressure test it and it fails, it may be repaired. however if it has been repaired more than a few times, it needs to be replaced.
stonyloam
Impeller pieces will be under the front endcap starboard side. "a" in the top photo. Any pieces that made it through there are probably long gone, but you can pop off the rear cap too, to make sure.
