havasuboatman
Ensign
- Mar 5, 2009
- 904
Re: How do you not become "that guy" at the boat ramp?
I build high performance boats and test hundreds of boats every year. I spend a lot of time running up and down launch ramps. I see the same thing every time I am down there. People back their trailers into the water too far.
If you aren't driving the boat onto the trailer. you are in too far.
The front 12-18 inches of the forward most bunks on the trailer should be out of the water.
This lines up the eye hook with the strap and v-block correctly. More importantly, it keeps your boat from drifting left and right.
When the bow touches the bunks, it stops the boat without damage (you don't hit the front of the trailer. If you are crooked, turn the wheel opposite the way you want the stern to move and put the boat in forward, straightening the wheel as the boat lines up. No backing up. the boat is straight over the trailer it centers over it by its self. Then gently increase the trottle and slide the boat up to the v-bock. If you are short a bit. Use the damned winch that is why it's there.
If you do it this way, you will never need someone with you. no matter how windy it is you will be so fast and accurate that people will stop and watch you. I swear to God.
I am on the trailer and up the ramp before people who were already in the water when I got to the ramp even have ther boats winched.
AND DO NOT TIE, UNTIE, LOAD, UNLOAD, OR WORK ON YOUR BOAT AT THE RAMP. If you do YOU are the ******* eveyone is talking about.
