Re: how do you keep the bonnett on the polisher?
you dont compound with a bonnet. Bonnets are made for glazing and waxing only. What you need is a wool compounding pad. Get a velcro backing plate and buy some wool pads with velcro backing. Make sure to "spur" the pad frequently to clean it, either with a storebought spur or with a dulled down screwdriver. Spurring keeps the pad clean andthe hairs separated so they can do their job. Also, dont mix chemicals on the same pad. For glazing and waxing, I prefer a foam pad to a wool one. You can buy em to fit the velcro backing plate as well. clean those with a stiff detailer's toothbrush. Just fire up the buffer and run the toothbrush over the surface of the pad.
