How do you handle 2 ft of snow?
ThreeMileBayWaker
Re: How do you handle 2 ft of snow?
hehehe,... Got a dustin' to an inch this morning,... Predicted 6" to 12"....
More comin' though....
We get that much but it never stays around, always blows into drifts around our camps. There will be barren grass in some areas and then 8' drifts around our garage and house up on the bay.
We've got a snow blower to tackle the problems tho. I laughed when all the folks down near the D.C area got some heavy snow. Couple feet and it was as if hell froze over, we just look the other way up and and continue on with life. 4x4 is a must have for at least one of the family vehicles.
NYGiants
we have maybe a slushy inch.
haha so much for the predicted blizzard
pmat1
i have a ariens garden tractor with a 40 inch blade on it. goes through 16 inches of snow like its not even there... even when the snow is higher then the plow, it goes :eek:
bowman316
yea, we had snow a ft above the plow, but when u have ur speed up, the snow gets swirling in front of it, and creates a wall above the plow.
Tainted Halo
in my place in canmore i had installed a heating element into the driveway 2 strands for each wheel ... every morning i had a clear path and got out fine with my two wheel drive truck...... i have seen a few guys who had wood boilers out on the farm and layed down pex tube under the cement to make a heat pad.. it worked fine as well another trick is to put a waterproofing agent on the cement from Cabot.... even the smalest wind and snow just zipps off.... if your on tar then use the Expressions waterproofer... after a few years it will faid the tar then you can just re surface it with sport coat.... or just give your drive a light dusting of salt before the snowfall :)
pongy
Geez, Seeing what you boys have to endure makes me glad I live where I do
I have never seen snow and can only imagine the problems it causes
Today in Adelaide South Australia the temp was 36 degree's celsius (About 96f in your lingo)
I went fishing today and while we didn't catch a whole lot, It was good to be out on the water
That snow stuff, You blokes can keep it, lol
itsaboattime
I picked up a 1948 IH farmall M that I put a laoder with a 6 ft bucket on. She don't even grunt when going through a 5' drift. I added live hydraulics and converted it to 12 volts. I also added a block heater for those really cold mornings. She never let me down.
You gotta keep up with it tho. I would plow during the storm, froze my boys off, but it paid off. Winter used to be my favorite season, but the older I get the less I like it.
I sold it on ebay last April, was gonna move to AR. That never panned out tho..........
skargo
Banned
yea, but those tractors have a limit. they won't go thru a 4 ft drift.
Mine certainly will!
4x4, diesel, rear locker, hydrostatic trans, front end loader, rear grader blade. She does well in deep snow.
ClassyGlassy
Here in Colorado above 8000 feet we start clearing as soon as we have about 4-6 inches on the ground.......sometimes we may clear the drive 4 or 5 times in a day!
I generally let it go all night so that I can get up around 5 and clear again if needed!
I use a Polaris Ranger 800 with a skid on the front....
bowman316
the most inporntant part of your tractor is that it has 4wd. you would be getting stuck on ice if it was only rear wheel drive
skargo
Banned
I still got it stuck once during this storm. It surprises me, especially with it having turf tires on it. I have some crappy chains for it but I can never figure out how to secure them properly.
I really want some industrial R4 tires, but you have to buy new wheels and everything!
bowman316
we just got chains for our tractor. you just need to put bungie cords around the outside of the wheel. in ax x pattern.
Stachi
If you're tired of anemic, one-lung snowblowers with their slipping drive belts, you might consider Kai Grundt's V8 snow blower which raises the bar on the traditional snow blower in every respect. With electric start, electric block heater, antifreeze heater and eight cylinders, it has no drive belts to freeze up and you'll never get bored with the job as the 454 cubic inch big block Chevrolet V8 produces 412 horsepower, 430 foot pounds of torque and can throw snow 50 feet at just 3500 rpm.
Nor will you get cold as the machine has been ingeniously designed to route the engine coolant through the handle bars, with the rear mounted, enclosed radiator keeping the operator nice and cozy.
Maneuvering the massive beast (it has a total wet weight of 912 lbs) is a breeze thanks to the hydraulic-drive 4WD skid steer on independent walking beams which offers a zero turning radius. It's also as fast as you like, with an infinitely adjustable speed range on the drive wheels via dash mounted flow control. At the opposite end of the scale, it has more than enough torque to pull your car out of the ditch before the hydraulic motors stall!
Adding to the well-balanced feel of the unit, just 15 pounds of down force on the handlebars will lift the auger blade off the ground in order to climb stairs/walkways for ease of snow removal. Safety has and continues to be paramount with spring return to centre "fail safe" type directional controls with emergency stop and tether cords.
Safety is one of the key theme, with a flashing blue light (as required by law in many areas) being the least of the safety features. No one will fail to hear you with those twin throaty exhausts, which come standard with 92 decibels at the controls, though if the rumble of a V8 exhaust is music to your ears, you can obviously go much louder. Even at the standard baffling, hearing protection is strongly suggested.
The powerful yard machine lights and a dashboard with backlit gauges complete the package to ease the burden of this normally reviled task. The custom 42 inch, two stage auger has a Chevrolet 10 bolt truck differential with spool and a centrifugal auger clutch with shear pin protection, further adding to the image of this "automotive theme blower." As each unit is custom-built, optional extras for the snow blower are both diverse and outrageous as the base unit - there is unlimited auger choices from single to multi stage designs and various motor combinations to suit the religious preferences of the customer (Chevy, Dodge Hemi, Ford) and such exotica as a V-10 or a diesel engine or remote starting can be accommodated. And if, after a while, you feel you've outgrown the 400 horses, this particular engine is well catered for in the performance modification area, with Lunati camshaft, Milodon Gear drive, Holley and Edelbrock components to name a few, and there's always the fuel injection option too, if you feel you need to throw the snow out of the county or insure your seat in the "neighborhood blower blingster hall of fame."
