how do you check fuel pressure
NO-IDLE
i have a 98 johnson 175 pump ball will not hold pressure motor will not stay at idle i have new ball pump & new fuel line from ball to motor how do you check fuel pressure
F_R
Honorary Supreme Mariner
With a fuel pressure gage. Not expensive, at auto parts stores. Usually combined with a vacuum gage. But not to be confused with one made for newer cars with fuel injection. They run at a much higher pressure.
F_R
BTW, the primer bulb is not supposed to "hold pressure". It is used to fill the carburetor so you can start the motor. One running, the pressure in the bulb changes to a suction as it pulls gas from the tank.
