how do u time a 1959 johnson superseahorse?
mattd20
i have a 60h/p johnson i had to take the timing belt off to put new points in and i lost its position.can u help?
Joe Reeves
Re: how do u time a 1959 johnson superseahorse?
Raised timing mark on top of block to rear of flywheel, slightly to port side (left). Line up flywheel mark with it.<br /><br />If magneto, line up pulley timing mark with center of safety cutout switch. If auto ignition, line up pulley mark with the mark on the dist and bracket.<br /><br />Install belt and tighten.
