how do i tell what size prop is on my force
my55
how can i tell what size prop is on my force 125hp all i see on there is the # 409 what do it mean i am in need of help <br />thanks
JB
Re: how do i tell what size prop is on my force
Did you take the prop off and look at the front surface?
lonewolf5347
13 1/2 by 15 check other reply below
CatfishJim
Most forces ussually come with smaller than normal props a force is like a yugo it will get you around but it wont take you there look for the numbers on the prop they should be on the casting somewhere cant find any take it to the nearest force dealer and tell them how ashamed you are that they carry force<br /><br />------------------<br />Everyday a catfish is just around the way.<br />Maybe today a big one<br />will take my worm away
mbb
if you pull the prop youll find it. It can be stamped on back, or even inside the prop.
