66evinrude
Thread starter- Joined
- Jun 16, 2011
- 91
well finally had my boat out yesterday for first run worked ok missed a little at idle but other then that not bad. well today had it running in my yard in a drum doin some carb settings i shut engine off now it dont want to start its got good spark both plugs took carb off all good very clean. i tryed sqeezing primer bulb with gas line off the one that hooks to the carb shot lots of gas out then tryed pulling engine over with the same gas line off gas just dribles out how else could i check fuel pump or anything else that may cause this problem? o and the plugs are dry so i know its a fuel issue and engine is 1966 evinrude ski-twin 33hp
