How do I tell if my Alpha One water pump is bad
Lameduck2
2010, 4.3L TKS, closed cooling system, belt driven seawater pump, Alpha One stern drive.
The engine cooling system is working great, but how do I tell if the pump in the outdrive is working correctly. I bought the boat used. I was originally told the I didn't need to put the ear muffs on the outdrive, just the toilet plunger on the seawater inlet. I ran it a couple of time that way. No telling what has been done before I got it. When I run it with the ear muffs there seems to be water forced through it - water comes out around the bellows.
The oil looks good. Is there an outdrive temp sensor? the manual says there is, but I think that is a misprint (I think it means oil level for the monitor, not temp).
Thanks for any help
Bt Doctur
The impeller in the outdrive is needed to cool the oil. when converted to FWC system ,the connector hose is cut and the inside part is capped.
Never run a outdrive without water. if you damage the water pump base seals, you lose the oil , then the drive.
Lameduck2
Is there a way to tell is the impeller / pump is good or bad without taking the unit apart? Can you tell if the water pump base seals are damaged without a tear down?
Starcraft5834
How do I tell if my Alpha One water pump is bad?
your engine will overheat....... if your not overheating and it's running great.. what's the problem?
Lameduck2
Thanks Bt Doctur.
Looks like we're in for some exploratory surgery. The benefit for making sure it is ok seems better than the potential cost to wait and see. I know I ran it dry for a few minutes a couple of times, and who knows what the last guy did.
Do the pump kits I see include everything I'll need?
Lameduck2
All seals and O rings soft and pliable. Impeller in very good shape. Bottom plate a little scored. Pump housing looks good. However, the yellow seal carrier under the pump plate is melted. The seals and O ring in/on it seem fine, but the top of it is melted and mushroomed over.
I’m not sure that the melting would affect the seal carrier performance, and in another life I would probably have cleaned it up and reused it along with everything else. For $125 it’s getting everything new while I have it apart - and I’ll always make sure it has plenty of water when I’m running it on the beach.
Thanks again Bt Doctur
