2010, 4.3L TKS, closed cooling system, belt driven seawater pump, Alpha One stern drive.
The engine cooling system is working great, but how do I tell if the pump in the outdrive is working correctly. I bought the boat used. I was originally told the I didn't need to put the ear muffs on the outdrive, just the toilet plunger on the seawater inlet. I ran it a couple of time that way. No telling what has been done before I got it. When I run it with the ear muffs there seems to be water forced through it - water comes out around the bellows.
The oil looks good. Is there an outdrive temp sensor? the manual says there is, but I think that is a misprint (I think it means oil level for the monitor, not temp).
Thanks for any help
Thanks for any help
