How do I tell if my 8MLHV has a charge coil.
leblancr
I'm trying to help my son figure out if he can charge his battery from his 8MLHV kicker motor.
There are 4 wires coming out from under his rotor.
I've tried to find wiring diagrams, etc, but have had no luck. When I looked up parts I saw 3 coils, a charging coil, a lighting coil and a pulsifier coil. But how do I tell what is there? And what would he do to set it up? I've seen references here to adding a voltage regulator, but haven't had a lot of luck finding what one he'd need.
Can anyone point me to any wiring help for this?
Also, if you know what a reasonable output would be, that would help. He has a lot of fishing equipment so we're sure it won't keep up, but if it could help keep up, that would be nice.
Thanks in advance for any help.
99yam40
lighting coil is Yamaha's battery charging coil.
possible green wire coming out from under flywheel
generally a lighting coil is about a 5 watt output (enough to run lights). a charging coil is a much higher 50 watt output - enough to recharge the batteries after starting and running for a while.
99yam40
The charge coil on Yamaha's is for charging up the CDI ignition system to fire the plugs
