how do I remove this gear from the housing?
so
want to take this gear housing apart and inspect the inside but cant seem to find a way to do it. Am I suppose to remove the pin from the plastic clutch hub first? I already tried tapping on it with a 16D nail, no movement though.
thx
Honorary Supreme Mariner
The pin is likely bent and it will take some brute force to get it out.
so
is the pin tapered in the middle so that it only comes from one end? tapped on it really hard and only budged little.
The pin is not tapered !----It is bent, you need to apply some force to it !
Chinewalker
Punch it out. Try not to damage the plastic hub. Once the hub is off, the rear shaft carrier will slide off the propshaft.
interalian
It's a 1981 2hp.
Suggestion to the OP: you have a lot of different threads all about the same motor. You might be better off posting it all in one for ease of reference. And has this motor been dunked in the lake?
boobie
Thanks interalian. I've always worked on the big stuff and didn't recognize this part.
so
not sure if it's ever been submerged, I dont know the history of the motor...
wanted to merge all threads into a "rebuild" thread, but doesnt' look like there's a way.
interalian
A moderator could do it, or just post in one thread with the various questions added as required.
