How do I make a connector for fuel line to Motor?
IBrokeMyFreakinNeck
I bought a Merc fuel line at walmart for my 1972 merc 115 Inline 6 and of course it doesn't fit. Can I just make a connector to connect the fuel line to the motor? If so, what do I need? Thanks.<br /><br />Billy
gewf631
Re: How do I make a connector for fuel line to Motor?
Billy,<br /> I think Merc uses some different fittings over the years, and also depending on the size of the outboard.<br /> For example (I 'm posting this picture off Cabelas site) <br />
<br /><br /> I think your fitting looks like this one<br />
<br /><br />which came from our friends right here at iboats. <br /><br />Just click on Marine Mega Mall at the top of the screen, and search for Mercury Fuel Fittings
IBrokeMyFreakinNeck
Ed,<br /><br />The one I bought from walmart looks like that one, but it seems not to be deep enough inside the fitting to connect. Is there a difference?
gewf631
My connector looks very similar to the one in the picture. It's a push and turn process, so maybe you're missing part of that.<br /><br />I'm not an expert, so I really can't comment on whether or not there's a difference. You might want to look over at Merc's site, plugging-in your S/N, to see if there's any info (they've got some VERY nice exploded views).
bluebyyou
Should be able to just push it in a twist 90 degrees. I've used the Schlock-mart fittings b4. Good Luck.
andrewkafp
The inlet on the motor has a small spring loaded spike sticking out. Your female fitting has a ball bearing and rubber seal about 15mm inside. Push it on hard and turn it clockwise and anti clockwise until it goes in another 10-15mm and then turn it back until locked. I'm sure you have the right fitting. Merc ones are all the same.<br />IMF .. Sounds like you are gonna need a lot of advice from the guys on here.. which is really good because that's why we all come here.. to teach and learn.. ;)
IBrokeMyFreakinNeck
Well I had to really push on it and turn it to lock it with the help of some channel locks. I have to get a couple of fittings for the temporary tank before I can fire it up. Thanks for the help guys. <br /><br />Unicorn, your right I'm going to need a lot of help from this site. <br />By the way, why don't you send some of those fine looking Australian blondes to New Orleans for Mardi Gras! I would love to show them a good time! :D But don't tell my wife :eek:
Elmer Fudge
How are you gonna do that with a broken neck ?.. :p <br /> "sorry wrong forum"
andrewkafp
IBMFN<br /><br />Well.. you are welcome to any of the "Blondes" except mine.. : :eek: <br />We are very open and freindly here.. but there is a limit to our hospitality.. :D <br /><br />BTW You didn't mention the gender required for the "Blondes"... ;) ;) <br />You need to be be more specific in your request.
IBrokeMyFreakinNeck
female!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!<br /><br />I may have broke my neck but I sure didn't break the bone that counts :cool:
Hooty
If it was mine, I'd remove the disconnect and run the hose directly to the fuel pump. I personally feel like there's to much restriction through it. I'd also install a good filter/water separator in the line.<br /><br />c/6<br />Hooty
y not
Absolutly top idea Hooty
