Re: How do I get the prop off?
I had a prop that was hard to come off. The corrosion was so bad. I soaked it and heated it and worked on it for over a week. I ended up pulling the prop right off the hub, destroying the prop. Once I did get it off, i clean the shaft real good and greased it up before I put the new prop on.
You have to keep at it. You may not be able to save your prop. A good penetrating oil to use is PB Blaster. I bought a can at Autozone. I noticed Wal-mart has it also.
Just make sure once you do get it off, you clean up all the corrosion and grease the shaft before putting the new prop on.
