Re: How Do I Get Roll & Tip Finish Smooth
A couple of thoughts... I assume given your attention to detail with heat and humidity you sanding between coats? You can knock off a lot of the nubs between coats with 220-400 grit or a scotch brite sanding pad (i like the latter)...
Also, I used a combination of roll n/ roll, plus roll 'n tip... I would roll out about a 4 square foot area with the wet paint - it would have some bubbles in it... Then, would take a semi-dry roller that hardly had any paint on it and I would come back over it... You don't won't to hear any kind of "sticky" sound as you are going back over it... If there are still any bubbles after that, you can take a high quality brush and light go back and forth until you smooth at all out...
The important thing is to work in small sections and be sure you come back over it before your little section starts to dry... Then, move on the next section..
I have not worked with your particular type of paint, but I think "lakelover" rolled and rolled his boat using Petit Epoxy and after an initial learning curve with the paint, his turned out quite nicely...
