How do I get a bumpy finish with gel coat?
Mark42
Parts of my boat have a bumpy surface. Supposed to be non-slip, and it is applied where ever the top side is reinforced for walking on. Looks similar to latex paint applied with a cheap-o roller. Was wondering if I used a roller to apply the gel coat would it come out the same?
tashasdaddy
Re: How do I get a bumpy finish with gel coat?
mark, i read something about glass beams, adding them to the mix. something you mix in the gelcoat.
tashasdaddy
yeah, thats the stuff. glass beads/polymer beads close. can't expect an old man to remember everything.
fishingdan
Have had good luck using the non-skid additive above. I like to then apply a final coat of paint (without non-skid) over it.
I am anxious to try a product from Cabelas called tuff-coat. I have seen a boat with this finish and I think it is excellent.
flashback
I have put gelcoat on with a foam roller and have had good results.. enough texture to create quite a good non-slip surface..
JustMrWill
Master Chief Petty Officer
That "Thicken with cabosil to ketchup..." was something I posted a long time ago...guess what...I should be trying it in the next week or so..will let you know how it comes out.
-JMW
