HOW??? Do I convert to battery ignition on a 73 Chrysler 70hp?
wildways1976
My friend and I picked up 2 Chrysler 70hp motors.(really clean) for a less then fair price. (Old man didn't care) Problem is we are not getting any spark anywhere... We have checked the cap, rotor, plug wires, points gap, and so on...Our conclusion is the coil or control box is bad... We have been told we can convert it to Battery Ignition with a few simple parts from a car.... I have some what an idea but would like to know for sure.... Any suggestions on what parts and how to install this setup would be greatly helpfull..:D
Frank Acampora
Re: HOW??? Do I convert to battery ignition on a 73 Chrysler 70hp?
If the distributor already has points and not the electric eye, then all you need to do is buy a 12 volt coil and mount. Blue wire goes to positive on coil, and neg on coil goes to points terminal on distributor---That's it.
Be aware though, that the electronic ignition-- even the old style points signaled one is far superior in spark and the engine will idle better. And, if you go to The Chrysler Crew, you may be able to find a CD unit for a reasonable price.
wildways1976
Thankyou..... Do I need a coil with the ballist resistor built in???
What vehicle can I match that coil too?
Frank Acampora
yes and No, you need a coil designed to be charged with 12 volts or one with a ballast inside so it can handle 12 volts at the terminals. I don't know what autos had them.
Auto starters draw so much current that battery voltage drops to 9 volts while cranking. The coil is designed to operate on 9 volts to ensure maximum spark at cranking. However, once the engine is running, the coil would get 12 volts which would shorten its life so a dropping resistor is in the run circuit.
on outboards There is no dropping resistor at run so the coil will always get the full 12 volts. Starter motors are relatively smaller than auto starters and draw less current so battery voltage does not drop as much during cranking. Thus: you do not need a ballast for when the engine is running and yet full voltage is still delivered to the coil at start.
McGR
Putting a ballast resistor/coil ignition system is not necessarily a bad idea. It will provide a hotter spark during cranking. Basically, ballast resistor type ignition systems place a set of relay contacts across the ballast resistor that is in a series electrical path with the primary side of the coil. During cranking the contacts are closed which bypasses the current around the resistor, effectively removing it from the primary circuit. Once the motor is started and is no longer cranking, the relay contacts open and reintroduce the resistor into the primary coil circuit. This scheme provides high primary current during cranking and lower primary current while running. In short, the coil more or less gets a current boost during starting, resulting in a nice hot spark to get the motor started.
The downside of ballast resistor ignitions is the parts count and wiring complexity. In a non-ballast type systems you simply have a set of points, condensors and primary coil in the primary circuit. In ballast type systems, you have points, condensors, the coil, the resistor and a relay + all the additional wiring. Either scheme will potentially work. However, if you are experiencing a weak spark during cranking the ballast type system will prevail.
Personally, I would go with the simpler non-ballast approach first. If I determined the cranking spark was weak, I'd change to the ballast type system.
To identify a coil (wheather ballast resistor type or not), I'd look up in a parts application guide some old vehicles (60s/70s) and see if a ballast resistor is required. If a resistor is shown you then know the status of that system and can use the coil from that system if desired.
wildways1976
Thank You!!!!! for everyone's insight on how to run this... It was alot easier then I thought it would be.... I did however find that it was better to use a coil with the ballist in it.... I'm getting every bit of spark that the factory one would have kicked out....
Here is a parts list of which I used:
Spark Plugs: Autolite-4093
Condenser : BWD - G126
Ign Coil : BWD - E502
Coil Wire : OMS - 7A323
All these were available at O'Reilly Auto Parts for $40.00:D
If anyone has any questions on how to run this I can give direction from one side to the next. Message me at wildways1976@hotmail.com
Any idea on how to hook up a Tach to this setup????
McGR
Let us know how it worked once you get it up and running.
wildways1976
It runs great, Now I'm just curious if this engine requires engine oil for the bearings?
And would like to know how to hook up a tach?
