How do I convert my 75HP Mercury from oi injection to premix?
thekozz
Hi,
I have a 75HP Mecury. I want to covert it from oil injection to premix. Is there a kit or does anyone know of a procedure that I can perform? I believe that it is a 88 motor. Any information will be greatly appreciated.
Re: How do I convert my 75HP Mercury from oi injection to premix?
Hi,
Ayuh,.... Just don't put oil in the tank,..??
Movin' to the Merc outboard forum...
Laddies
Banned
Remove the pump and remove the driveshaft for the pump then reinstall the pump, to keep the pump and drive from self destructing
Texasmark
Laddies sir, I did this recently on my 3 cyl 90. All that I removed was the ss drive gear which was part of a shaft with a slot in the other end for running the pump. Somebody on here said that I had to remove something else at the gear end of the shaft, like a stop to keep the shaft pushed up against the pump, keeping the slot engaged. I looked at my IPB and saw no other part. Did I miss something?
Thanks,
Mark
Laddies
Banned
No, removing the shaft and gear is all you need to do.
Bobv
Thanks,
Mark
Any problems since you did this? I'm doing the same to my 88 75hp. Thanks
Texasmark
None other than a tad more smoke at idle, but I use synthetic blend oil so the smoke isn't that bad anyway. However........I did write on my boat adjacent to the fill plug: Add 1 pt of oil to 6 gallons of gas just so I wouldn't forget. Years and years ago premix is all you had so you became accustomed to it. Then 5 years ago I buy this automix engine and all I do is put gas in the tank. So, I have to remind myself to add the oil.
Mark
Bobv
Thanks for your input, I've been trying to find out how to do this for a while now.
1nebel0
Here is another twist I did... I have a 90h.p basiclly the same motor...I took the hose coming off the oil pump drilled a hole in the tank at the top, put a grommet in and put the hose in there... I am using the oil that is in the tank as it recycles itself through the oil pump and then back into the tank..This way everything is right there is someone buys the boat-which they are doing now and can make up their own mind...The large engines have a plug that replaces the pump to hold the plastic drive gear on the crank in place. Wished they made them for all of the motors...Anyway, Laddies is the expert, I just cheated....
Bobv
How did you block off the input to the fuel pump where you removed the hose?
Bobv
Thanks,
Mark
I've got the pump off but the shaft w/gear doesn't want to come out. Am I missing something? Thanks Bob
Bobv
Answered my own question. There is a block (oil pump adapter assembly) that stayed on the engine when I removed the pump, it needs to come off and the shaft comes with it. All good. Bob
davem1901
I have same question as Bobv. I like your solution as it keeps the pump working but you avoid relying on it to service your engine. Sounds like a winning idea. I am new to this sort of thing, but it looks like from the diagramoilpumptracker75.jpg you should be able to just replace the molded fuel line (part 25) with a straight fuel line. No oil to the gas but is recycled to the tank. Easy conversion back if someone wants to.
Comments on this would sure be welcome.
