How do I connect service tachometer to two stoke motors?
Tinkerer
I shouldn't need to ask this because I worked it out about a year ago after blowing a tach on a two stroke lawnmower, but I can't remember how I hooked the new one up right. At $100+ a tach, I don't want to blow another one<br /><br />On a two stroke motor with no distributor, how do I hook it up for service tasks? <br /><br />This is a general application question rather than a given model. I've currently got a 1964 Mc Culloch 7.5 hp and a 1970 4 hp Evinrude that I might want to hook up, but there will be others.
Hooty
Re: How do I connect service tachometer to two stoke motors?
G'day ( I learned that from those Australian blokes) Tinkerer.<br />What are you tinkering with today? What kind of tach are you attempting to hook up? Is it a 2 cyl. tach? Maybe you could use some JB Weld?<br /><br />c/6<br /><br />Hooty
Tinkerer
G'day, Hooty. <br /><br />I've finished tinkering with a 1953 4HP British Seagull, which is either a magnificent piece of elegantly simple engineering or just plain primitive, depending on your viewpoint. I was tempted to keep it but it's a bit hard to justify two 4 hp, one 5 hp, and one 7.5 hp motors when I've only got one boat they can fit. You can see the mighty British Seagull here:<br /> http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=2422179783&category=32630 <br /><br />I've finished tinkering with the Mc Culloch, which I picked up with frozen gears and no spark. It goes a lot better now that I've freed the gear actuator arm and put the gear detent rod on the correct side of the gearcase. Finding the key in the gearcase and putting it back in the driveshaft/diff pinion slots was a useful improvement as it now allows power to be transmitted all the way down to the propeller, which I think is always a nice feature in an outboard. The tilt also holds a lot better now that I've dismantled the latch and reinstalled it 180 degrees around. It seems to do the job a lot better when it can actually hook onto the rod rather than just foul it. Fortunately I didn't bend any of the parts I had to straighten out and re-form where someone had gone to a lot of trouble to assemble it a*s backwards (I got that from you guys up there). <br /><br />I am currently tinkering with a 1970 4 hp Evinrude Lightwin, which wasn't going when I got it but I've got it sort of operational but still needs sorting out to run properly. I'm wasting time trying to make a friction cylinder for the throttle lever out of bits of hose, because the part ain't available any more. Simple part, but hard to make.<br /><br />And the eternal project is the bloody 1967 Evinrude V4 60 hp on the 15 ft boat, which now has both heads off. I'm going to pull it down in the next week (I hope!) to make sure the pistons are OK before getting some re-ringing parts from Joe Reeves, who is a very handy man to know. <br /><br />Naturally I couldn't have done all this without resorting to JB Weld, which has been very handy in fixing holes in the cylinder heads for water cover bolts where drill ran off centre. Buggered if I can get them to go straight in, even with a drill press and pilot holes. <br /><br />Tach is car tach for 4/6/8 cyl but I can do the math for fewer cylinders if I can find the info I've got stored somewhere. Have to know how to hook it up first.<br /><br />Today is obviously a day where I have way too much time on my hands.
Yepblaze
There are so many types and models of tachs that are so specialised to their own application that I doubt you will have much sucess with what you are trying to do.<br /><br />If you just need a tach for tuning or max RPM you might be best served by one of the tiny tach models. Although, once again even they have various models for various systems.
Paul Moir
The way I see it, the tach needs a 12v pulse to count. Your outboard (the 'rude) gives you two direct pickup possibilities - the -90v secondary pulse and the ignition pulse (~25000v), which can be easily picked up inductively. Either way, your going to need a rectifier/amplifier/one-shot. The one-shot lengthens the pulse for the tach, and may not be necessary.<br />Alternatively, you could paint a target on the flywheel and connect an optical sensor (perhaps scavanged from VCR) to the tach. <br />I guess the question is, do you tinker with electronics? If not, the tiny tach is a great thing. If so, I may be able to help you a bit further.
