How do I clean carb on old 20hp Mercury????
lunkerhunter
Guys, any tips how to do this? My motor is the one where the throttle automatically engages the drive based on how much you rev it. Thanks for the help! :confused:
12Footer
Re: How do I clean carb on old 20hp Mercury????
What year motor is this (abt)?<br />On the older models, the carb has the intrigal fuelv pump on it.<br />The carb kits are pricey,and do not come with the fuel pump diaphram..Odd, huh?<br />Also ,the float level adjustment is extremely finicky.<br />They are simple to remove. Undo the fuel input hose from the side, the two 7/16" nuts,nd the thing slides off. You will need to take a finger,and lift the throttle advance plate (plastic so be carefull) off the throttle advance arm (also plastic).<br />You'll have fuel pump and carb in your hand.<br /><br />
<br /><br />Semper Fi
