How do i check the block for cracks
tightboathole
Wheres a thread to pressure testing your block? Like what tools and equipment needed? How do i do this!!?!??
tazrig
Re: How do i check the block for cracks
Here are a few posts that cover that. The motors are different brands but the way you test are basically the same depending on if it is a closed or raw water cooled engine.:
http://forums.iboats.com/mercruiser...k-pressure-test-results-confusing-599266.html
http://forums.iboats.com/mercruiser-i-o-inboard-engines-outdrives/water-oil-600593.html
Also here is a link to service manuals for your engine to cover anything not covered in the threads provided:
Boatinfo - The library, containing manuals, brochures and other technical documents from the last hundred years!
