How do i check for sheared flywheel key
bktheking
Re: How do i check for sheared flywheel key
Pull the flywheel off.
Chris1956
Remove the spark plugs and turn the motor until the top piston is at TDC. Use a screwdriver to get it as close as you can. Now see if the timing marks indicate TDC as well.
