how difficult to replace water pump on this?
imported_rusty
hi everyone i have a 1983 johnson 35 hp how hard to replace impella? is there a shift linkage to disconnect? I also have an extension added to this to make it into a long shaft if that matters. thanks rusty
aanda6
Re: how difficult to replace water pump on this?
Hi rusty, If you have the manual it is really easy. If not you should get one, If you don't have a manual you have a fool for a mechanic.
imported_rusty
have a manual its an older one that covers several models and years i just wasnt to sure about the shift linkage and was hopeing for some hands on experience .
aanda6
On my motor the shift linkage is under the carb. You need to unhook the pin in it before the leg will drop. It is a bit fiddly but once you've done it a couple of times it is pretty easy. Also you need to remove the bolt under the fin on your skeg plate. Probably best to get the complete kit instead of just the impeller, that way you know that your seals are good.
imported_rusty
thanks andrew i was getting charged about 150 bucks everytime i got it done and since i use the motor all season and in the winter for duck / goose hunting i like to have it changed more often than not. i have a ton of tools and can do just about anything just wanted to do some research before i jump into it. thanks
aanda6
No probs, I am the same. I don't know much apart from what I read on this forum and in my manual. But most of the stuff is pretty easy if you take your time and ask the experts here for help. Good luck with the water pump, let us know how you get on.
imported_rusty
hey andrew what time is it in australia? lots of gators over there?
aanda6
Rusty it is 11am. We don't have no gators in Australia, Crocs in Qld.
imported_rusty
oh, hows the fishing over there?its 9.23 pm here.
aanda6
I only spin and fly for trout in the streams, and been too busy getting boat ready for ski season to go fishing lately. When you shange the water pump it may be worth checking the tstats and watre cases around the cylinders. I changed my water pump last week and nothing, took out tstat full of crud, removed heads and were full of crud too. Obviouslt the previous owner didn't flush. At least when i'm finished I will know how old everything is.
imported_rusty
will do andrew ,i just did the pump on my 85 force not to hard just heavy lifting the lower unit up trying to get the drive shaft up in the proper place. changed the thermostate in that one.
