how can i tell what lower unit i have
okbayliner
i have a 1990 force 90 hp outboard 906x90c model # 906x90c.I got a new impeller that i ordered online but was a little to big so i went to a store thay gave me the same one went back with lower unit then got the right one. Now i need to replace the seal around the drive shaft but dont know what to get and dont want to get wrong one
Frank Acampora
Re: how can i tell what lower unit i have
The 1990 lower unit was made in three versions: A, B, and C. However, all used the same size water pump impeller. It sounds like you have an earlier lower unit with the smaller (in height) impeller.
A photo of your lower unit would help.
jerryjerry05
F4305 seal
F69430 seal
F694305seal
F694961 retainer
There are 3 seals in the drive you have for your motor. The question is, is the drive original?
The first drive made for that year uses a different seal than the later models.
Yours if right uses the parts I listed.
Look on your drive and find any #s or codes.Take pics and show the drive and numbers and letters..
Is it leaking at the seals?? If not? Don't mess with it.
okbayliner
it has a one piece drive shaft the top of the water pump housing has 523060 on it trying to get pics up but not working
Frank Acampora
One piece drive shaft is earlier than 1989 and has the Force water pump. The later two piece drive shaft lower units used a Mercury water pump and the impeller, while the same diameter, was about 1/8 to 1/4 inch higher
jerryjerry05
You'll need to resize the pics to post.
okbayliner
looks like i found the right part thanks for the help
okbayliner
the # 523060 on top of water pump is for 80's lower unit so going to try water seal for an 85 should work will update after I try it
