Re: How can I tell if my engine is making the amount of power it should?
I have a 1988 2.3liter. I run a 13-3/4 x 15 prop and WOT is about 5200. I can get 38 mph by myself and about 34 with 4 adults. With that prop I can get about 32 mph at 4600 rpms...the last few hundred rpms don't result in much of a speed increase, the prop is too small. With a 13-3/4 x 17 I can get a little more speed, but can't get above 4800 rpms so I think that's too much for my boat. I also have much better performance pulling skierws with the 15. I think it's the right size for that 2.3l OMC Cobra. (My boat is 17-1/2 feet)
If you truly have a 15 on there it sounds like an engine problem to me.
By the way, the number should be stamped on the prop hub when you look at the back, not on the side of the prop. Is that where you're looking?
