Re: How can I get more from my 50 4 stroke merc
Persuit, maybe this will help some. This is all from memory, so numbers won't be exact.<br /><br />I bought a new 1987 Bayliner Trophy CC with a 125 Force, and it came with a 19 pitch aluminum prop. WOT would only give me about 35 mph at around 5000 rpms. And I sucked fuel like crazy at at rpm "below teeth rattling in waves" cruising speed. <br /><br />So, I got up with parts guy at the dealership, and turns out he had the exact same boat. He had also tested every prop in the dealership, and told me to get a 17 pitch. WOW!!! I was running over 1,000 more rpms at any given speed, but my boat throttle seemed barely cracked, fuel economy went up, and it would rev to 6000 rpms and hit close to 40 mph. I would never have believed the difference it made, if I had not done it myself.<br /><br />Since then, I've experimented with any boat that I own and I try to set it up so that it will redline on calm water with my lightest expected load in the boat. This is my "everyday" prop, since I mostly fish alone now, at least from my boat. Then, I buy a spare (that I take boating with me, along with an extra prop nut, etc.) that is 1" or 2" less pitch. I also swap it on the boat, for the times that I have heavy loads in the boat, or skiers, etc.
