kevinhart992
Thread starter- Joined
- Oct 14, 2021
- 2
I have a 2009 Sanpan pontoon boat. Recently I was not getting auxiliary power unless the boat was running. I charged the house battery but it would not fully charge, so I went and had it tested and sure enough it was a old bad battery. I replaced the battery with a new one.
Then I started the boat everything worked and the VSR module light came on, but when I shut the engine off the VSR would stay on for about 10 seconds along with auxiliary power. Then the light would shut off and I would lose my auxiliary power. Yesterday I started the boat and now I have no auxiliary power and the VSR module light does not come on. Also my starter battery is new as of this year.
My configuration is a starter battery and a house battery each with a separate on/off switch and a VSR module between the 2 switches. I did take the house battery switch out and check for continuity and it was good. Could it be the VSR module? Or something else?
Any help is appreciated.
Kevin
Kevin
