FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1996 30HP evinrude, mod#E30TEEDE. Is there any way to hook up an hour meter to this motor? A small meter that would fit inside the cover?
THANKS, JOHN
Hour meters are pretty common, I believe you can get one at Harbour Freight, then you just need to find a switched power source on the engine to power it.
Tiny Tach inductive rpm gauges are also hour meters. They are small and can be installed in a few minutes. They are also inexpensive. Be sure to order the two stroke version.
Install a blocking diode between the rectifier and the connection strip. Then take the power for the hour meter before the diode. Hour meter will then only get power when engine running and charging.
You will be hard pressed to fit either a 2-inch diameter or one of the rectangular "powered" hour meters under the cowl. Vibration and heat would likely kill it. However, Tiny Tach does make a very small unit and it is self powered so no power connection is required. They include a tach function and the only connection is the sensor wire that simply wraps around one of the plug wires.
