Hot Water In The Bottom Of My 1994 Bayliner Jazz Jet Boat
kmartin
Re: Hot Water In The Bottom Of My 1994 Bayliner Jazz Jet Boat
2nd try on pics.
If you still can't open, send me your email address, I'll try that way if you like.
kmartin
Don't know where the images went. What am I doing wrong???
Zamboni
Not sure about pic posting karen but that sounds like blower vent anyway.
With a little luck your hot water leak will be that clamp or the rubber boot its holding in place-seen that before.
Just a suggestion but most of the SJ questions are in the PWC forum. There are a few in merc forums sometimes but suggest you post any further questions in PWC if you want them noticed. Some good reading on SJ's over in PWC forum also you might find interesting.
marine4003
A whole lotta luck:D:D:D
Hitech
To post a picture here you first need to host it somewhere on the internet (like www.photobucket.com). Then you can link to that. You cannot link to a picture on your hard drive as the rest of us do not have access to it.
Zamboni
Its a longshot, the exhaust manifold is a heavy gauge on those engines though so rarely a prob. If that box does go it usually spews exhaust gas into the engine compartment though so I'll stick with the clamp/boot on bottom where it attaches to drive housing cover. Brittle rubber tears or clamp goes, only allows water out at high rev when jet pump forces more water pressure thru the system.
Hope she comes back and lets us know.
kmartin
I'm still here... Just waiting for shop manual to come in and the time to work on engine. I'm shooting for Saturday/Sunday. I'll let you know how it went on Monday. Thanks for all the help.
kmartin
Thanks Hitech for the tip about posting a photo.
kmartin
Hope you guys are still reading... 3rd try on pics. [
kmartin_025
Let me know what you think. K--
kmartin
Hey, Hitech, I'm still doing something wrong with the pics. I used photobucket like you suggested. Everything OK on that end, but when I try to insert the URL in this message board, I lose the link. Any suggestions?
Hitech
I'm not sure what you are doing wrong. You can see how I posted the link and images if you click on "Quote" in my post.
Typically you can just include the url with out the tags and the forum software will add them for you. The img tags have to be included to get the picture to display instead of a link. To post a link to the photobucket album go to the album and in your browser's address line select all the text and the edit/copy. You can then paste that into the post and you will get a link. If it doesn't generate a link, edit the post and put url and /url tags around the pasted text. To post actual images click on the bottom link in photobuck for the picture. That will copy the necessary text into your clip board. Then paste that into the post. It helps to have two tabs in the browser or two instances of the browser running when doing this. You can repeat that to include more than one picture. That is what I did.
Zamboni
Here is a link to the pictures:
http://s345.photobucket.com/albums/p398/kmartin_025/
And a couple of pictures:
I don't know anything about jet boats, but I can help with the pictures. ;)
There is some corrosion visible on top of the exhaust manifold-bottom where the boot/clamp are is hidden by battery in the pic.
I'm off for a weeks vacation Saturday morning so won't be around-good luck!
kmartin
Thanks again, Hitech. Now maybe the other guys can take a look at the pics too.
Hitech
You might want to try the PWC section.
Anyway, back up to the top.
arboldt
kmartin, I finally had this issue fixed with my jetboat. Here's what I'd suggest:
1) If you haven't gotten a service manual yet, go over to jetboat14.com and join there. Go to the Jazz section and ask around. That's specific to small jetboats. I'm sure someone there can help you find a service manual fo rthe Jazz and also for the SportJet.
2) Make sure your drain plugs are in, then put the boat in the water -- have at least one good helper on board with you. Don't even leave the launch area if you can help it. (You'll need to move out a little bit 'cause even in neutral there's some propulsion thrust). There should be a pin on your throttle assembly to pull out so you can rev the engine slightly without really engaging the drive jetpump. (Turn the steering wheel so you go slowly in a small circle). Now lift the engine hatch and make some careful observations.
a) I doubt if your drain plugs are leaking, but look there.
b) Look at all the water hoses leading in and out of the engine to see if there's any leaks. I bet there won't be.
c) Look carefully around the base of your sportjet engine. For me, there was a small but steady stream of water between the engine and the jetpump housing. There's a gasket between the jetpump and the engine that went out on mine, and based on what you've said (hard landing on some rough water), I'll bet that's what happened to you, too.
d) There may be other points of failure, such as the exhaust manifolds, but that's unlikely. Look around anyway while the motor is running in the water to identify everything you can.
e) Also check your bilge pump and the fuse to it. If you've got that much water, it's possible you blew the fuse (happened to me, too).
As soon as you identify where the water is coming in, get back to the ramp and pull your boat out.
IF this matches what you see, then you'll have to pull the engine to replace that gasket. There are some photo sequences on jetboat14 on doing that, but unless you're really handy and knowledgeable, I'd suggest you have a good marine mechanic do it. In any event, when the engine / jetpump is reassembled, make sure that *every* bolt is properly torqued. (If you don't have a good torque wrench don't even try it yourself). The first mechanic I had work on our boat didn't properly torque everything... and I just got it back from a good mechanic with all 3 pistons brand new, cylinders re-bored, etc etc. So please don't let this happen to your boat.
Hope this helps.
Al
kmartin
Hey Zamboni & Marine 4003, this is Karen. You guys nailed it!!! I called my cousin who works on cars, asked him to take a look. We put the boat in the water at a ramp on the river that leads to the lake. Never even took it off the trailer. I told him to look at the exhaust manifold clamp and boot. Sure enough the water was running from the clamp. He tried to tighten the clamp, but ending up breaking it. Before he broke it, he got the water to a drip in a couple of places. He also said the boot was hard as a rock. Now I am going to take it to a marine mechanic my cousin knows that does excellent work in his backyard. I'm going to have him look at the bilge pump too. I don't think it's working either. I'm hoping to get the boat to him this week, but I haven't heard from my cousin today. I'll let you guys know the $$$$ after I get it back. Thanks SO much for all your advice and replies to a "newbie." I really apprecitate it. And AL, thanks for your reply too.
Zamboni
Good to hear that's all it was Karen-lucky guess on my part. The boot/clamps can be replaced by sizing at NAPA etc so cheap...I was in some big storms on Lake Simcoe last week and was glad to have a hi-cap bilge pump...get a good replacement.
I'm Cujo31 on site Al mentioned, couldn't get that nick here. Good site, slow but its specific to jet boats-good reading.
Scout Sport Fish
Gentlemen, what we have here is a jet boat..the water pickup is a grate located on the bottom of the hull,like a jetski,theres no way to land-run this puppy.
Karen...for future reference ,these boats don't have a real deep "V" hull,so take it easy on the waves,my SR120 had to have engine mounts replaced due to my frolicking in the waves..
Have you ever worked on a boat? :confused:
Most (I say most because some engineer was retarded enough not to include one) jet drive crafts include a fresh water hook up to flush the engine of raw water.
kmartin
No, I haven't ever worked on a boat engine, so I finally gave up and took the boat to a guy who fixes jet boat engines in his backyard. He was recommended by another boat mechanic. So now I wait... I'll let you guys know something when I do. May be a week or two. Karen
