haulnazz15
Thread starter- Joined
- Mar 9, 2009
- 3,720
Alright electrical guru's, I have a bit of an issue. With a cold engine, everything starts up perfectly with no issues, the blower (electical bilge blower) operates, as does the bilge pump. Guages all work perfectly. After running for a bit 20-30 minutes, we shut down the engine just to inspect things and look things over (new engine approx 3-4hrs).
Now the issue: when we go to restart with the engine hot (i just mean warm, temp around 130-140) the engine will crank about 1/4 turn and stop like the battery is dead. The blower will not turn on, nor does the bilge pump. So, we let it set for about 15 minutes or so to cool off, turn the key, and it fires up like nothing was wrong. We go ahead and run it the 30 minutes or so back to the ramp without an issue, and the blower was working when we pulled the throttle back at the no-wake buoy. WTH?!!
Fast facts:
Had starter rebuilt when we rebuilt engine
Blower is new Rhule inline-type
Battery is new, which is a replacement of previous new battery that we thought was causing this issue.
Battery positive and negative 4ga cables are new.
Alternator is original 1976-spec, but amp gauge shows a positive charge when engine running.
Guage needles operate correctly regardless of electrical issue
I'd really like to figure this one out since it's the last piece of the puzzle to getting the boat back to it's wonderful self!
Fast facts:
