Hot light issue 200 hp high output etec
scottandee
Just bought sea Ox with 2008, 200 hp high output Evinrude Etec. 130 hrs on engine but not really used in last two years. Salt water use. Took boat out yesterday. 6 mph thru channel for 35 min. Then increased speed to 20. After 5 min. Hot lite and alarm came on. Engine DID NOT go into safe mode. Idled in neutral for 2 min and lite went off. Increased speed again to 10 mph after 5 min lite and alarm came on again..waited 2 min, lite went off again. Spent rest of 5 hrs "cruising " at 5 mph. Water was coming out indicator nozzle. With good flow. I am confused as to what is causing this issue. Motor was serviced with new water, fuel filters and new plugs. Have no history of t stats or water impeller or pump. Also what is a pop it valve? Can anyone steer me ? FYI, have been boating for years but this is the largest hp and most technical engine I've owned.
jakedaawg
Replace impellar and give it a try.that also could be one of the ones that needed the oil lines re routed.
scottandee
Replaced impeller, replaced two t stats.....computer codes show temp hit 214 degrees. Tech told me I might have fried the comp board. Codes also show 1 injector was not pulsing. Coded 64 times. Could lack of oil in a cylinder cause the overheat? Is the oil delivered to the cylinders mixed with gas ? If the injector was not pulsing would that lead to no gas/oil and hi temp? Tech still working on it but this is costing me a bundle....
