Hot battery terminals
UNCC Grad
1989 Mercruiser 3.0L
After charging my starting battery, I tried to crank the engine and it starts the first time. I then shut it down and try to restart and the starter slows down dramatically and fails to crank the engine. The + and - wires to the battery, to the starter and main ground, are extremely hot. I tried an additional battery that is known to be good and the same thing happens.
It sounds like a short somewhere causing the heat to build in the wires so my first step is to clean and/or replace the terminals. What else do I need to check?
Don S
Re: Hot battery terminals
Loose battery terminals cause that. make them shiny clean, throw the wing nuts away and get some regular nuts and tighten them with a wrench.
Could also be the ends of the cables where they go into the crimp on terminal is corroded. If so, replace the cables.
UNCC Grad
Don, I cut back the cables and replaced the terminal ends. I'll have to try to see if replacing the wingnuts help.
Could it possibly be the starter? I doubt you recall, but I had forgotten to put my plug in a couple months ago and water got up below the bottom of the starter before I got the water out. I'm just wondering if there could be a short in the starter somewhere and it needs to be rebuilt? I want to pull it as a last resort b/c I just replaced it a couple months ago before flooding the bilge and it's not easy to get out.
gooders
I had same problem hot battery terminals.Be sure wires are in good condition,no doubt you will have done that. However, I had to change my starter as well as it was toast. Result, cold and normal battery terminals. Hope this helps. :)
UNCC Grad
I checked all the wires, replaced corroded terminals and checked with 3 seperate batteries with no change in the situation. I pulled the starter and took it to the shop and the armature is fried. Hopefully this will take care of the problem. I'm guessing when I submerded the starter it eventually caused a short and fried the armature.
