Hot battery cables
mudbug_4
I noticed the other day that my battery cables were extremely hot to the touch after only a minute or so of idling...any ideas?
Thanks,
KM
alldodge
Thanks,
KM
Howdy
Resistance causes things to heat up when voltage is applied, can also be caused by a battery having a bad cell. Start but checking the charge of the battery. The motor should be turned off for a couple hours, reading should be around 12.6V. If bat checks out remove the cables and clean them, which also includes the ends attached to the starter and motor.
F_R
Honorary Supreme Mariner
Thanks,
KM
Both cables were hot? Are they the correct cables? Heat in any wire is caused by a high resistance or by an excessive current passing through them. It would take an awful lot of current to heat up a battery cable, for instance a starter that is running. Or a dead short somewhere.
oldboat1
What motor do you have?
Would check and clean cable connections, and check polarity. I've had wires heat up in a starting circuit that had issues during starter draw, but haven't run into battery wires heating up while operating. There are various wiring diagrams linked in the "secret file" up at the top of the forum (Mastertech site). You might have some miswiring, and might want to check for that first. Don't run it that way.
mudbug_4
Thanks for the quick replies. oldboat1, I have a 1989 Evinrude 110 VRO V4 (bought it used). @F-R, only the positive cable was hot to the touch. I did find a bit of exposed wire on the cable itself...guessing that doesn't help things much! AllDodge, I will try and borrow a battery tester from someone to see what the reading is.
Another tidbit of info is that my battery drains very quickly just be being hooked up to the motor for more than a day or two. Not sure what would be drawing on the battery (bilge and lights are turned off and key is in off position).
oldboat1
think I would pull the battery off and test it or have it tested -- might be the source of the problem when starter draw is applied.
[edit. Still a mystery re. phantom draw -- draw high enough to produce heat. Would want to be sure the battery tests out before proceeding, though -- i.e., problem not the battery itself].
emdsapmgr
A long shot. Make sure the starter is still not running/spinning after the engine starts. A locked up start solenoid can stick closed, constantly spinning the starter. You'd never know till you shut the engine off and heard it spinning...
