Hot Alarm
Rad Chad
I have a 1994 Bayliner Trophy with a 2003 150 hp Johnson 2 stroke outboard model #J150PXSTM,
I just changed the Impeller Kit, plugs,thermastats and lower gear oil and water sperator. I did this for maintenance and mainly due to the alarm came on saying it was hot and water was not coming out pee hole..
With some great support from here i was able to change the above.. Although now water is coming out good from pee hole, it is a tad irregular real hard then slower but keeps flowing. The water fells alittle warm then cool...Engine sounds and starts great assume everything was 100% but then alarm came back on and went off but light stays on. At this point i have no clue what to do
Rad Chad
does anyone have any thoughts, was going to run and shot the heads at different points to see the actual temps. Could the sensor be bad? should i take manifold off? as i said water id coming out telltale
oldboat1
What were the temps and at what points on the heads? (or do you mean you are going to do that? Good idea, but don't need to run it balls to the wall before getting a reading -- don't want to do that if it's overheating.)
Chris1956
Honorary Supreme Mariner
If that motor is like my '98 Johnny 150HPV6, it should have a strong flow out the telltale, even at idle. I therefore suspect something is wrong with the waterpump.
My motor uses a wedge shaped plastic drive pin to turn the impeller. It must be locked into the impeller and driveshaft to work.
Therefore the right wedge (kit comes with two different ones) must be used, and the impeller only can be installed correctly, one way. Then the driveshaft is turned CW to lock the drive wedge into place. Did you do all that?
The water pressure at idle can be 10PSI. At cruising speed the water pressure is 30+PSI.
oldboat1
If going back in to check the impeller, check the water tube grommet as well — grommets can be a source of problems in reassembly. I think yours has some protection from a cover on top of the impeller housing, but check to make sure it’s there and intact.
Rad Chad
I agree it could be, but i was very careful to replace it the way it was. I bought the whole kit not just the impeller and replaced all gaskets and o rings. I know what your talking about the lock wedge thing was tough. I do have good flow, ran it again today. But alarm kicks on after a few minutes and then goes off and light stays on. When i unplug 585023 — TEMPERATURE SWITCH, PORT it goes off and that switch has 2 wires, and everywhere i look the part is not available, not knowing if it is bad or not. The 0585184 - Temperature Switch other side remains plug in and no alarm. I have no clue just been looking online for answers
oldboat1
Are you running in water or on muffs? If the latter, see if you can test it in the lake or in a deep barrel -- water pump has to be covered (5 or 6 inches over the pump). Can't really test the water pump operation on muffs.
Rad Chad
i did not shot the temps yet my friend has that temp gun and he is not around will get tomorrow
Rad Chad
copy it is on muffs, i have ran before on muffs without problems. (maybe not as long) i think i have a barrel i could use would rather fix home and launch ones if possible over an hour to the river. I will run in barrel tomorrow and shoot the temps. do those two temps each control there side and can they go bad. what temp should i see when i shoot?
Thanks for the replies a little stressed out about my boat..
oldboat1
Don't know if your motor has the SLOW feature -- if so, would kick down to 2000 (2-3000) rpm if the port sensor reads an overheat (correctly or not). That would be for running in the river, as you shouldn't be running over a fast idle anyway on muffs or in a barrel. Operating temps, generally speaking, should be in the 130 to 140F range. Anything over 160F is overheating. Check temps on the top of the heads. Would be hotter on the face, around the plugs.
Rad Chad
thanks will do and report back, i don't think mine has that slow mode people speak of. I guess i wiil check temp and idle in a barrel and go from there.After that can trouble shoot, here people speak of false over heating, bad sensors, clocked manifolds and head gaskets. I changed the T-stats when i did everything else knowing that could have been a issue as well
F_R
Worthy of repeating--you cannot test a water pump by running on muffs. It is not pumping when you are doing that--only allowing the hose water to flow through.
oldboat1
sounds like the folks around you have a good handle on overheating issues. River running can be a little hard on impellers (sand). Will look to see what you come up with.
w2much
And make certain your intakes are clean and unobstructed. You may also do a backflush.
Rad Chad
well i feel i have bad sensor. I flushed engine again took t stats out and ran for a few seconds to flush that way as well. I placed it in a barrel and filled it up. Ran engine and put a gallon of simple green in there to clean...i let it run with temp sensor unplugged and ran perfect heavy stream out of tell tail, and stayed strong... Plugged in sensor and alarms sounds then goes off and light stays on and for some crazy reason the stream of water became more irregular , heavy then light. so i un plugged infrared temp gun, not sure where to shot but shot all over, the sides of heads were like 142 to 146 and the face by plugs were like150 to 155, highest any where was like 160 ran e 45 minutes and temps never went up.stream stayed good and luke warm... where the sensor goes in a threaded spot on block inside was 152 and alarm was to sound 170 or higher. unless some one knows something i feel i just have a bad sensor and my motor is not overheating.. i feel alot better know was stressed out. bad thing is this part number is not available anywhere and some places says it is obsolete.. was pondering threading in a temp gauge where the sensor was since it is threaded and adding a temp gauge to my dash if possible. Tanks for the help and perhaps this info could help someone else. If anyone as any other thoughts other than mine let me know. i will be running it the way it is with sensor unplugged till i add a temp gauge or somehow find this part...
