Hose to tell tale fitting specification help
aok47
Hi there,
What type of hose (spec & inside diameter) should I use to replace the hose from crankcase to telltale. I found the part number (0331215) but cant seem to find details
Outside diameter of hose measures 0.416" (10mm) and inside diameter approx 0.23" (6mm).
Appreciate your help!
AK
F_R
0331215 is a special molded hose. Regular hose may not bend sharp enough without kinking.
iggyw1
Ensign
If you use a "regular" hose and it won't bend sharp enough without kinking, just add an elbow to it and you should be all set to go.
