Silvertip
Honorary Supreme Mariner
Thread starter- Joined
- Sep 22, 2003
- 28,772
Re: Horsepower or torque
QuietCat -- You said (and its true) "Another misconception is that the vehicle with the higher engine out torque number will always be the better tow vehicle. In reality it is torque at the wheels, not the engine, that ultimately matters for startability i.e. gearing. If you have the same vehicle with two different engines, one with half the peak torque at the same RPM as the other, they can have equal startability if the lowest available gear (+ rear-end ratio and tire size) is double numerically on the lower torque engine. This would theoretically give equal torque to the wheels." The problem is you tied this to the term "Tow Vehicle." While startability in your comparison is true, you are right back to the point of my original post, the smaller engine screems its guts out at highway speeds due to the deep gearing. Your point is strictly applicable to startability -- Heck I pull my boat around with an 11 horse garden tractor. It has good startability but its a darned poor tow vehicle.
