Hope outboard ain't too heavt
KJM
I just put my 2016 F90 Yamaha outboard on the back of the Grew 194 I/O converion I'm working on. Man that motor looks big and heavy back there! I hope she isn't too heavy on the back end or too top heavy. The old L6 165 i took out weighed more but also sat lower and further ahead. I guess time will tell, but I'll definetly be trying her out in the nearby small lake before puting her in salt water.
88 Capri (2022 SOTY)
Master Chief Petty Officer
With you commenting like you are you sound concerned or possibly anyway. Taking a chance without solid knowledge could lead to tradegy so maybe instead of "time will tell" maybe get some sound advice first before taking a chance?
Emerger
The short answer is, it isn't going to hurt anything. An F90 weighs about 375 pounds, which is about the weight of two people. It will look a lot different than it did before now that the engine is sticking up above the transom but it isn't going to change anything.
KJM
It will be well tested in fresh water before hitting salt water. Also I doubt anyone could definitely say "yes this will work or no it won't" when its an I/O boat that wasn't designed for an outboard. Hense "time will tell" (but with lifejackets firmly on!)
KJM
Thats what I expect too.
Chris1956
Your IL6 plus outdrive weighed 650#. A lot of that is the outdrive which is at the stern of the boat. I expect the boat to float much higher with the OB.
