Hooking up the batteries
tcramer23
Okay- I am semi-new to boating. Bought a 2005 Tahoe 195 deck boat with a trolling motor and had a GREAT time with it last summer. It has 3 batteries in it. I had someone winterize it and they took the batteries out for me and I kept them charged over the winter. Now I have no idea how to reconnect the batteries with all of these wires!!! I have looked all over the internet and I cannot find any diagram. It has two deep cycle batteries, a cranking battery and a charger. Any help would be greatly appreciated!!!
5150abf
Re: Hooking up the batteries
Welcome to iboats.
I don't know that there is or ever was a diagram for that, people add or alter stuff on boats all the time and with out a pic or description of the wires you have to work with it is impossible to say.
Generally grounds are always black and any wire that is colored is a positive.
roscoe
Without seeing all you have to work with, hard to tell for sure.
Starting battery will get a red and a black connected to the engine (or battery switch).
May also have smaller wires for accessories, bulge pump, and nab lights.
If you have a 24volt trolling motor, the 2 batteries are connect (pos to neg) with a jumper, to create 24volts.
Then the to main lead are connected to the other 2 terminals.
But if you have a 12 volt trolling motor, the batteries are connected pos to pos, and negative to negative, still giving you 12 volts, but more running time.
The charger presents more possibilities, depending if it is a 1 bank, 2 bank, or 3 bank charger, and whether it is connected to the starting battery or the trolling motor batteries.
Best to find someone that can id all the wires for you, perhaps the guy that did the winterizing.
Just don't hook up anything backwards, or it can get expensive.
Silvertip
Honorary Supreme Mariner
It is essential that you determine if you have a 12 volt or a 24 volt trolling motor. Diagrams for both of those are as follows: PAY ATTENTION TO THE DIAGRAMS OR YOU HAVE SMOKE AND FIRE.
This is 24 volt (SERIES) wiring for a 24 volt motor.
This is 12 volt (parallel) wiring for a 12 volt motor:
If you have an on-board battery charger, it gets connected to the batteries like this for 12 volt PARALLEL wiring:
Or like this for 24 volt (SERIES) wiring:
The starting battery has a big red cable (goes on POSITIVE terminal) and a big BLACK cable (goes on NEGATIVE terminal). The "Boat" wire harness usually has a smaller red and black pair that also go to the POSITIVE and NEGATIVE terminals respectively.
tcramer23
Thanks for the diagram!!! I got it all hooked up and working!
