AL350SEARAY
Thread starter- Joined
- Jul 2, 2011
- 33
Thanks in advance. my engine is a mcm 255 350cid gmc serial #5375179. I bought this boat last year and only did small maintainance like changing motor oil, lower unit oil, fuel water separator and oil filter. It ran fine all summer. This past winter and spring I replaced water hoses, impeller, thermostat, plugs,wires,and went through carb as well as the same maintainace as the first year. First time in the water it ran fine up to 1500 rpm then it bogged down. It does not turn off it just will not throttle up. Thinking i messed up the carb rebuild i purchased a new quadrajet carb from a place i found a link for here on these forums. Same problem. Took it to a shop and they told me the mechanical fuel pump was not working properly so i bought and installed a new one. Same problem. Now turning my attention to the engine internals i checked compression and found a dead cylinder. when i took the valve cover off i found that the rocker arm on the dead cylinder had fallen off of rod. thankful to of finally found the problem i fixed it, adjusted all the rocker arms and put it back together. when i tried to start it the engine had no spark. i went and bought a rebuild kit for my electronic distributor, cap, and ignition coil. now it starts but i still have the same issue as before. nothing above 1500 rpms. when i was messing with the distributor i noticed the wires were not in proper sequence and the number 1 spark plug wire was not lined up with rotor when engine was at #1 tdc. it is completly on the opposite side. when i changed out the wires i did them one at a time so it is the same order as last year and it does start right up and run. when i tried to set them in correct sequence starting with where the rotor was at tdc the engine would not even start. i am sorry if this post has been extremly long. any help would be greatly appreciated.
