NirrtGritty
Thread starter- Joined
- Nov 16, 2008
- 2
About three months ago we had tremendous rains here in Florida and I seemed to have gotten water in my external gas tank for my BF 25. I noticed this after installing a separator. I drained the tank and all the lines and have run fresh gas through the engine including changing the plugs, oil, oil-filter etc. Now, the engine runs poorly and stalls. Almost as if its running on the top and bottom cylinder and not teh central cylinder. When I take the plugs out the top and bottom are dry and very hot, while the central plug looks "wet"and not that hot.. but the wetness does smell like gasoline.
1: Often stalls at start.. stalls when you engage the prop or when the engine is in the water. Runs rough after a few cranks at idle and I can hit the gas, when flushing, and it seems like its got good power except when you drop it back to idle it bounces around a bit.
2. Perhaps I'm hypersensitive now, but it looks like more whitish smoke is coming out of the hub than I remember when being flushed. Please help. Thanks
