On a trip this past weekend in our MacGregor 26x, our 2000 Honda BF50 developed an intermittent problem.<br /><br />Engine ran great for about 2 hours, cruising at about 5,000rpm. Engine started to lose power, and I assumed tank #1 (6gal DuraTank) was empty, which it appeared to be. Switched to tank #2 (6gal DuraTank), and we continued on our way. A few minutes after that, the engine began exhibiting the problem that would plague us for the rest of the shortened trip.<br /><br />We'd be cruising along, engine sounding fine, then suddenly the engine would lose power, running very roughly with a dramatic drop in rpms. This would happen whether we were at high rpms or moderate rpms. Pulling the throttle back to idle would result in the motor dying. Pushing it forward did not produce any noticeable difference in power, aside from the more "throaty" sound of the carb's valves being opened wide. After a period of time, anywhere from a few seconds to a minute or two, it would jump back to full power and run fine. This cycle repeated over and over at random intervals.<br /><br />I immediately suspected fuel contamination, since the problem seemed to coincide with switching to the 2nd tank. There did appear to be some debris in the tank, though I would have thought that this would have been caught by the canister-type filter/water separator that is installed. I drained the float bowls several times, and switched to a 3rd tank, but the problem continued. After anchoring overnight, hoping that whatever the trash was that I presumed was in the carb(s) would have settled to the bottom of the float bowl, I drained them once again, but after motoring for 10 minutes or so, the problem started happening again.<br /><br />After sailing most of the way home, we employed the motor to get us through the bridges, and the problem worsened to the point where it was barely running at all.<br /><br />Now, though I've thought all along that it was likely a fuel problem, however, I'm now having second thoughts about this. After sharing my woes with a slip neighbor, he suggested that it could be ignition related. Hearing this made me realize that the nature of this loss of power was not gradual (as in, taking a couple of seconds to go from normal power to running poorly), but rather very abrupt and sudden, like a "run crappy" switch had been flicked. Likewise, the regaining of power was similarly instantaneous.<br /><br />Running the boat at the dock (in gear, 3,000rpms) for about 10 minutes (that's all I had time for yesterday), all was well, but it probably just needs to be run longer than that for the problem to show itself.<br /><br />Any thoughts on this? Any ideas on what I should pursue first?<br /><br />--Mike
