Lacabana
- Jan 27, 2024
- 3
Hi,
I just got a new boat with a used (130 hours) Honda BF200 outboard. I bought mufs so I can flush the engine on my driveway directly after returning home.
After some 3 minutes running the engine the audible alarm for overheating comes on. Water flows properly from tell tale and exhaust at the prop.
My Simrad MFD is reading a 60-65 degrees Celsius which seems fine. However I’m not sure if this readout is reliable and what sensor is being used for the NMEA data feed.
The display for the engine is not giving a temperature reading at all just -/-, other data such as rpm, trim, etc do work.
Maybe the limited water pressure here in the Caribbean is the issue?
Thanks in advance for some guidance.
