Honda B100S
kfriesen
I need to change the gasket between the oil filler cover and the engine. I can see water leakage from arond two of the bolts that hold this cover so i assume the water is also getting into the engine. My oil is milky colored which means h2o. I can get at one bolt easily and another with some trouble but the other two not at all. Any info or help would be great. Seems i need to remove the power head but need to know the steps involved. I only need to raise it about 2 inches to clear the case.
