My friend's B-100L (B100L-L300668) turns about 1/2 turn then locks up. History - former owner said he could slip the belt off the cam pully/sprocket, align it, then with some starter fluid could start it. (Engine appears well cared for - clean oil in crankcase, no external abuse to powerhead, drive unit/prop, or skeg, spark plugs look reasonable.)<br /><br />A timing belt should arrive in the mail soon. <br /><br />Question - can someone advise me as to timing marks, etc.? I'll get a manual if I have to, but trying to get this done quickly - trading engine repair for a sailboat ride - wishful thinking. <br /><br />Question - if the timing belt slipped and caused some valve/piston interference, is it possible to have a bent valve(s) or damaged piston and cause a compression loss? Any "quirks" I should know about this model? <br /><br />Thank you all!
