Skiffman12
Thread starter- Joined
- Jun 1, 2008
- 2
Greetings;
I have a BF90 Honda (unsure of year) which idles smoothly and runs steady up to about 4000 rpm. Recently replaced all four low speed jets and soaked and cleaned the carbs. Appears to be fuel starved and rpm's will surge for brief period if choke is applied and then returns to 4000 rpm. Normally achieves another 1000 rpm on normal day. All four cylinders appear to fire. Normally motor achieves over 5000 rpms and runs steady. Is there an inherent problem with the high speed jets? Suggestions would be appreciated.
Thanks in advance.
Thanks in advance.
