makassiouk
Thread starter- Joined
- Aug 2, 2010
- 12
Hello, everyone.
The engine is generally healthy and what bugs me the most, has JUST been overhauled by a good mechanic, which included cleaning the carb, after which it started on 1-3 pulls and ran like magic.
Today I went fishing for the first time after not using the boat for about 3 weeks. The engine started fine (with 2/3 choke), I let it warm up a bit, with little-to-none choke. Idle was a tiny bit rough, but nothing major. When I set it on idle for the first time, it ran for about 3 minutes and died. Since then I could only start it with either choke or some throttle and it'd always die quite soon on idle or close to idle. When I try to start it warm with no choke, it'd sound as if it catches and dies off immediately.
The plugs are 1 month old and adjusted, oil's in order, no detectable problems with the prop or anything else.
I have a suspicion it might be either condensate or some grit in the fuel tank, which was stored in a rather damp place for 3 weeks, half full (although tightly closed). What should I check and is there a way to condition the fuel somehow to remove condensate and clean out eventual b/s from the carb without major mechanical work (I really don't want to pull the boat ashore before autumn)?
Thank you!
Thank you!
