Fishin with buds
- Apr 13, 2007
- 31
So i picked up my used 2003 Honda 225 used about 160 hours ago. I have had no issues besides debris blocking the tell tale-but the engine would still cool. I just changed the oil and filter for the first time on my own at about 150 hours. HOnda marine 5w-30. The first trip out, about 3 miles out the jetty at about 3200 rpm's the boat set down from a small wave. The same time this happened, the engine rpm's dropped about 2-300rpm's. after going a few more minutes it happened again, then again, then every time i set down from a wave. Flooring the boat resulted in it boggng down severly. However, i could rev it in nuetral with no problem up to 6000 rpm's. I decided to go slow and the engine ran fine under about 3200 rpm's. but whenever i set down from a wave(maybe at the same time increasing the load on the engine) the engine would drop rpm's. I have not changed the fuel/water seperator in the time i have had the engine(150hours since time of problem) and have not changed the spark plugs and do not know when they were changed previously. The problem occured after i changed the oil.
any thoughts? could i have overfilled the oil and be triggering a sensor that would put the engione in a safe mode if the oil got too high? or do i need to change the fuel filters and water seperator? seems to me if it is intermittant, it would be an electrical issue, not fuel delivery. any help would be greatly appreciated as i am running low on cash and the YFT are BITING!!!
Thanks
Thanks
