Honda 100 10hp
-JR-
I have an old Honda 100 /10 hp motor that i will be using as a kicker or a backup if the main engine fails.
It has a DC outlet plug on the out side So I hooked up a volt meter and the voltage starts at 6 v at idle and goes as high as 32. volts when wide open. Will it regulate it self when it is hooked up to a battery to around 14.5 at full speed.
