Bt Doctur
- Aug 29, 2004
- 19,493
I made this to remove the oil line when the gimbal housing needs to be removed
WITHOUT BREAKING THE PLASTIC NIPPLE,I designed it to cut on the up stroke thru the oil line 1/2 to 3/4 in length .Replacement hose is approx 3 inches longer than oem
1/4 inch SS rod heated red hot then hammered flat. formed as shown about 14 inches long.
grind to a knife edge and hone like a razor blade.
Swing housing fully left cut thru hose and it slides right off.
For the gimbal side raise the drive fully, and there is just enough room to cut the hose off the brass nipple.
