Holley 2V tuning
ss9940
Hi all!<br /><br />Is there a manual on-line on how to tune a Holley 2V carb? The prod. no. is 3854086 (3857982) - it's for a 3.0 Volvo Penta engine.<br /><br />Thanx!
ss9940
Re: Holley 2V tuning
Come on guys.. it's a 2 barel Holley on a 3.0 Volvo penta engine. I am looking for a manual on how to tune the gas / air mixture!! All the experts, come out :D <br /><br />Thank you, thank you, thank you...
Buttanic
You got to read the spark plugs and base jet size on how they look. There is no magic foumula. If you are referring to the idle mixture it is best done with a vacuum gauge and the mixture screws ajusted to obtain maxium vacuum at idle.
ss9940
Hmmm... ok :) If the sparkplugs are black, what does it mean? Too rich or too lean?<br /><br />Alex
jeff13601
Do you have just a single air/gas adjustment screw?
ss9940
No, there are 2 screws... 1 on the left and 1 on the right
ss9940
Buttanic, the sparkplugs are black-grey with no oil on them (it's a brand new engine)
Buttanic
With a new engine I would think the factory jetting would be optimal provided the carburator is working correctly. Usually jet changes are only needed when modifications have been made to increase preformance. Plug reading works best on new plugs. Put in a set of new plugs and without letting the engine idle for an excessive time run it at the speed you normally run at for at least 5 minutes than shut it down quickly without idling then look at the plugs. Do this on the water not on the trailer. It needs to be under load pushing the boat. In any case I would limit any jet changes to one size larger or smaller. Going too big will not cause engine damage, only poor performance but too small can cause major engine damage such as burning pistons. What is your reason for wanting to make changes?
ss9940
Only the base engine is new (GM 3.0 replacement engine), the carb is from the old engine (water in cylinders) - now i'm fine tuning the thing... The carb was untouched before i got hands on it - the screws were full painted, so noone messed with it till now. I had to take it apart cause there was sh** in it - looks like the engine was flooded through the carb (apparently a dead battery or bilge)
